Posts: 1,731 |
I am hearing this strange humming, almost a rubbing noise as I drive.. it isn't the engine making the noise and changes tones with velocity. Started when someone backed into my quarter panel, I don't think the tire is rubbing. Could it be the half-shaft? or CV boot?
Black 98.5 SVT
"Kellie"
First rule of italian driving: What is behind you, DOESN'T matter
Posts: 1,731 |
Could it be throttle hang?
Black 98.5 SVT
"Kellie"
Posts: 725 |
did the wheel get hit too or just the 1/4 pannel? it might be a wheel bearing too, i would check for wheel play by jacking up the car and by hand shaking the wheel up/down and side/side. i think if you have side/side wheel movements the wheel bearing is going and if you have up/down movements its CV boot.
95 SE MTX
DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
Posts: 1,731 |
I don't know if the wheel was hit or not.. there is no evidence of that. But I am definitely going to check those things.... thanks...
Black 98.5 SVT
"Kellie"
Posts: 36 |
99'Contour SVT #1766 of 2760
pionner deh-4400 cd/xm head unit
Koni adjustables w/ H&R sport springs
Yokohama ES-100 225/50/R16
Posts: 1,731 |
inspected everything initially.. tire is fine... everything is fine for the most part.. I am confused.. it just bothers the hell out of me!
Black 98.5 SVT
"Kellie"
Posts: 725 |
Are there vibrations or any other symptoms while driving? Does the humming get louder as speed increases, or do you hear the humming only at a certain rpm or speed?
My guess would be a bad bearing or unbalanced wheel, those are the only 2 times I had a humming sound coming from a wheel while Iā??m driving. With the unbalanced wheel my whole car was shaking but only around 55mph. With the bad bearing the humming was there the whole time and it got slightly louder as speed increased.
Never had any experience with a bent driveshaft on a Contour, but on my parents van it caused the whole van to shake and the humming was unbearable.
95 SE MTX
Posts: 1,731 |
It seems to get louder with a decrease in speed... I am thinking it is the bearing..
Black 98.5 SVT
"Kellie"
