its the most annoying thing i have ever had to deal with. every time i shift into third gear it will do it. will some please tell me what it is and how to fix it? Thanks
I'm assuming you have a manual transmission. The MTX-75 is a bit quirky like that. Check on the main website for the tranny coctail. It usually alleviates these types of problems, however, it is entirely possible you need to replace the syncros for 2nd and 3rd gear.
I'd start with the tranny coctail first.
-Jeff
-"The Crazy Canuck!!"
-"Rice": Anything that looks faster than it really is...
My Ride! http://members.sounddomain.com/sideoftheroad
Try the cocktail, but likely your syncros are shot.
How often do you change the tranny fluid? Old fluid will lead to these types of failures.
2000 SVT #674 - Check it out!
i havent changed the tranny fluid since ive had the car so its probably al most been a year and whoever had it before me probably didnt do it either so i dunnno
It sounds past a lube job...what year/miles do have on??
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
its a 98 it probably has almost 60000 on it
Syncros and blocker rings, need the latest 2000+ parts ..its expensive..
V6 MTX
