#594540 04/04/03 04:40 AM
CMAC Offline OP
I am planning the following mods for my stock block 2.5 as funds allow.
  • Fidanza flywheel
  • grizzly clutch
  • SHO Shop Powerset complete intake system
  • P&P of stock heads
  • SHOShop cold air
  • Superchip flash module
  • SHO shop Y-pipe
  • Cat back exhaust
Am I on the right path or am I wasting my time without the SVT cams? Will I need to in stall every thing at once since the MAF in the SHO powerset needs to be programmed? Any idea what kind of gains I could resonably expect? I'm sure this has all been covered and probably done before,but I'm still learning to navigate the site(I have 2 teenagers).Any input is appreciated..Thanks
2000 Contour SE,All stock and lots a fun,But I have plans
#594541 04/04/03 05:04 AM
9
depends on what direction you want to head, prob good for everyday civic ass kicking!!!but you really want to add the svt uim/lim and tb, no point opening up the exhaust if there isnt anything more to push out!!those two alone will make a big sopi
#594542 04/04/03 08:37 PM
CMAC Offline OP
The intake listed above is the SHO Shop modified SVT intake(ie even larger ports)60mm TB and 70mm MAF
#594543 04/05/03 03:27 AM
9
nice, i need the 60 mm tb and a larger maf wouldnt hurt
