#593806 04/03/03 09:28 AM
I just put a set of 18" rs-6 with a 215/40/18 yoko tire on the SVT. I have some tire rubbing, I noticed it on my way back from the store with a 40lb bag of dog food in the trunk. I was wondering if anyone could show the correct place to roll the fenders over/under to lose the rubbing?
Mat
'98 Black/Blue CSVT -#162 D.O.B 4/12/97- -----Many MODS-----
#593807 04/03/03 01:28 PM
O
O
I'm assuming you're lowered... what kit do you have?
Plain-jane 3.0L supercharged E0 FOR SALE OR TRADE FOR STOCK SVT PLUS CASH WTB- 36# return injectors
#593808 04/03/03 04:05 PM
i think that your offset is what is the problem. is it under 40? there are threads about where to roll the fenders throughout this section.
Oo (xxx)oO o xxxxxxxx o
#593809 04/03/03 06:22 PM
I just got some 18s with 215/35/18. I bet they will rub to with my ststem in the back.
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System 98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop 85 Toyota PU Lifted 06 GSX R 600 Black/Silver My Rides
#593810 04/03/03 06:32 PM
Your tires won't rub, my friend has P215/35R18 on his SVT with a system in the back and he doesn't have a problem so you should be fine.
Aaron
#593811 04/04/03 02:33 AM
I am running a Koni/roush setup, The offset of the wheels are 38mm, that's where in running into a problem. I've ran a search and there is alot of talk but not realy anyone saying the best or easiest way to do it, is there any help out there?
Mat
#593812 04/04/03 03:46 AM
Yep, 38mm offset is the culprit.
Is the tire rubbing the metal fender itself, or the plastic inner fender liner? Look at the edge of the tire where the sidewall meets the tread. Are there any marks or cuts on the tire sround this area? If so, it's the metal fender lip. If the fender liner is rubbing the tires, you will be able to see where the tire has "burned" against it. If so, you can probably just cut this out on the affected spots.
word.
Chicken Shift
#593813 04/04/03 05:19 PM
my 17's rub when i hit a dip at high speeds and i have a system in the trunk, you can just dremmel away the inner part of the fender correct? a friend suggested taking a wooden bat and having someone drive the car slowly forward while i roll the bat to push the fender up, good/bad idea?
"What did you think about that Dorothy girl?" "The whole Judy Garland thing kinda turned me on. That doesn't make me some sort of fag does it? "Nah baby, your money." 98 Black SVT #3560 of 6535
#593814 04/04/03 06:26 PM
rims and tires are too damn big... how wide are the tires? (i dont understand the # [censored] on the sidewalls i.e. 225/75/R15 please explain) lol.
95 GL MTX Zetec, Carbon Fiber hood: *neoprene seat covers *new SVT rear bumper *Proud Owner of 1962 Chevy Corvette 427
#593815 04/05/03 03:33 AM
My tire size is 215/40/18, they only rub on dips. I can turn the konis hard and no rubbing but the ride sucks. I think i will have to cut the small section that its rubbing out.
Mat
Moderated by  1314_dup1
