link 1 The Toyo® Proxes FZ4 all-season high performance radial meets the increasing demand for stylish, affordable, all-season performance radials for sports sedans and coupes. This V, W and Z speed-rated radial (depending on size) offers choices for plus sizing applications.
Styling, traction, and handling no matter what the weather! Contemporary sidewall design and aggressive tread pattern appeal to consumers seeking high-performance capabilities and great looks.
- Unidirectional tread pattern with double "V-shaped" lateral grooves for excellent water drainage and all-season performance.
- Large shoulder blocks and small, rigid center blocks, combined with a refined casing profile, provide a stable contact patch to ensure excellent directional stability.
- High hardness bead filler in the lower sidewall increases steering response and improves cornering stability.
- Polyester casing with two full-width steel belts provide increased strength and tread stability for improved handling and comfort.
- Jointless cap and edge ply construction delivers handling and high speed endurance.
- V, W and Z speed-rated (depending on size)
- UTQG Treadwear 300
- UTQG Traction A
- UTQG Temperature A
