Posts: 955 |
i dunno, if this is a problem or not. but my car whistles, when i accelerate heavily. i talked to someone, from ceg, and they said it might cause a lose of hp. but he wasnt sure.
i got a K&N drop in, with out intake res.
could it possibly be the transmission, earily signs of dying?
Experience is the worst teacher; it gives the test before presenting the lesson. "You peel my onion down to the nun" - Gene Hackman [Under Suspicion] -Walter- 96 Contour LX
Posts: 119 |
i have the same problem. i havent found out what it is yet. i have the same filter. someone told me that the air box might not be sealed correctly
97 se sport K&N drop in filter Sony Explod head unit Mille Miglia MM11-2 16x7 http://v6contourv6.tripod.com/pictures.html Looking To Get SVT side skirts indiglo gauges "How I wish, how I wish you were here. We're just two lost souls Swimming in a fish bowl." Pink Floyd
Posts: 955 |
Originally posted by v6contourv6: i have the same problem. i havent found out what it is yet. i have the same filter. someone told me that the air box might not be sealed correctly i checked that is pretty solid. mines like a turbine spinning, tyoe of thing.
Posts: 270 |
can it just be the intake sucking in air? have u checked to see if anything is in the intakes way or anything?
Black 98 Contour SE Zetec ATX 5% Charcoal-black tint (tint on exterior and interior) Knauberized on 5-05-02
Posts: 5 |
It's your intake system sucking air really hard and forcing it into the MAF. If it goes away I'd reccomend checking your air filter to see ift is dirty...another sign of this is gas mileage...other than that, there is nothing to worry about.
98.5 Silver Frost SVT Bone stock for now, but waiting for turbo and NOS
Posts: 704 |
Theres a TSB on alldata for engine intereference coming through the radio speakers and it makes a high pitchied whistle...check that
Originally posted by 99SESPORT: First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off... And sitting there telling him politely
"Please let go of my nuts, sir?"
Posts: 1,445 |
which side of the engine does it seem to come from? intake side or belt side?
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 620 |
do u have a turbo?  :rolleyes:
SVT EMBLEM MOD HERE :::96:C:LX:::Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels :::99:SVT:C::: #2566 of 2760 T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?) ..::nyceboicreations.com::.. email:junkmail@nyceboicreations.com
Posts: 70 |
I have a whistle under light or moderate acceleration. When I listen (adjust throttle by hand while in park looking at motor) it seems to be coming from the top center of the motor. I am convinced that it is from my secondaries being cracked. When ever I get the chance I'm going to return them to normal and see if it continues. Yours sounds like its different since its under hard accel. but just thought I would throw that out there
98 Silver Frost Contour SE Sport ATX BAT Handling Kit, SVT E1 Wheels, SVT TB, UIM, Airbox , SVT Exhaust, Rear Strut Brace, Pioneer Deck and 12 disc changer, Pioneer 6X8's
Posts: 3,584 |
After getting my true duals installed I too noticed a whinning sound, and it does sound like a turbo, kinda  :p
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
