#56463 03/22/02 08:50 PM
Okay quickly when you get new brake pads you don't need the rotors resurfaced right? If not the guy at midas is trying to hose me.
98 MTX SE sport
TH fix
Magnaflow muffler and res.
KKM intake
Yes it is a good idea to get them resurfaced it shouldn't cost much more than $10 a rotor.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
agree w/ above. If midas wants to hose you they will tell you have to replace rotors, calipers, ... stuff like that.
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
Thats what they are trying to do.
screw them performance brakes here I come
98 MTX SE sport
TH fix
KKM intake
Thanks for the speedy respone too. Midas wanted like 600 for the job.
98 MTX SE sport
TH fix
KKM intake
man, dont do that, brake pads are only 18 bucks at auto zone and they charge 7 dollars to turn them. any one can change pads. eek
9
9
Dude, Thats Crazy don't spend 600 buck with those rip off shops all you need is a Haynes manual for your make/model a few tools and you can do it yourself in a few hours and way less bucks.I always just replace the rotors with new ones they don't cost that much and less likly to warp.
Good luck
95 Contour 110K / Tranny slipping / Steering Play / Non-functioning door locks/
Replaced Both front Wheel Bearings exactly 1year apart/ Replaced coil at 105k/spedo cable and sensor twice
/Did TSB repair on Parking brake works fine now/Alpine CD Deck.
$600 will nearly buy your the BAER brake kit for the front!!!
Don't just walk away; run away swearing profusely!
2000 SVT #674 - Check it out!
Don't worry I've already been looking at upgraded brakes. I've already got the chiltons mannuel so I can do it myself. Soon I shall have truley impressive brakes.
98 MTX SE sport
TH fix
KKM intake
F
F
Unless your rotors are scored bad, warped, or have bad pits of grooves...then they don't need to be turned. Turning a rotor will cause it to break down and warp faster. When your caliper is removed, sand down the rotor surface by hand, in small, circular motions. This is just to remove any tiny imperfections and dust.
I went through three sets of pads on my Eclipse without turning my rotors, on thw third set of pads on my Wifes Mirage, and second set on my Cougar, with out turning the rotors once.
