I have a 98.5 SVT with the battery in trunk, due to SC. Right after the SC install I had the alignment checked and the steering wheel slop tightened down. Ever since all the stuff on my steering wheel does not work. No horn, air bag warning light flashing, and no cruise control.
Any ideas?
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
H
H
Scroll back a few days I seem to recall a similar post with possible cause/solution.
stock CD on LS, cass on LX
4 wheel discs on LX only
You have a clock spring problem. The flashing is 3 then 2, right? I have te same thing. From what I understand it is a $40.00 part with about 1 hour worth work. Do a search for code 32 or 3-2 for more info.
1998 Contour 2.5 Non-SVT (ATX)
SHO Y-Pipe
K&N Drop-in
