E
E
well, ive got sort of a metallic noise that is (i think) coming from the right side. there is also vibration inside the car, and when i turn right the vibration stops. i've done some searching, and i think it might be the front passenger side wheel bearing. what do those sound like?
now officially a troll, i guess. used to have a black 96 SE, until it broke down one too many times. now I'm hunting for a motorycle.
I
I
It sounds real bad. I had the same one go on me. From the out side it sounds like a tank or something like that, loud and drone grinding.My dad could hear it 2 blocks away from our house if he was outside.
98 SE V6 MTX T RED bridgestone potenza re950 open air filter side makers and removed ding guards , gutted percats, no muffler SVT brakes SpecIII cluch and spec flywheel torsen diff soon
Yeah, sounds like a bad wheel bearing to me. I just had one replaced a month ago. PM me if you want to get together and have me take a listen.
Scott
Troll! '99 BMW 328i
E
E
Mine sounded like I had monster truck tires on when it got pretty bad.
1998.5 E1 SVT Contour #5482/6535
Sounds like a loud humming noise.
99 CSVT Green/Tan # 84 of 2760 Built on Wednesday, September 30, 1998 15.376 @ 92.00 MPH Stock 75,000Km 96 Contour GL 2.5L V6 ATX 170,000Km
E
E
thanks for the offer pidgeon, cars at the dealer now. we'll see what they think. had my dad, whos a car guy take a listen, he thinks its the wheel bearing too. dealership will probably try to tell me its a million other things too, but we'll see about that
ill keep you guys posted.
Which dealer?
Troll! '99 BMW 328i
had one done a couple of months ago - independent garage in Webster - $200
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
F
F
Had my rear ones go bad couple years ago, replaced under warranty! Thought it was bad road noise ,but didn't change pitch when the surface changed, then thought it was my borlas, or even engine noise. It made a roar the faster I'd run, so by process of elimination and through the dealer we had them replaced, cured the noise.
My rear wheelbearings sounded like I had big mud tires on or maybe someone was running a grinding wheel in my back seat.
My front bearings were a bit less intrusive but they affected the steering and the feel of the suspension too. They made a sort of thunking noise when making small direction changes at speed, and the passenger one made a noise similar to the rears when turning hard left.
don't drink and drive.
