#587460 03/28/03 12:12 AM
Ok, I have a 2000 Contour SE Sport. I just wanted to see if anyone knew if this Head Unit would fit in my Car. And yes i did search before i posted this. The head unit is a Blaupunkt Tampa Bay
Im probly thinking i need a harness connector or soemthing?
Can anyone help?
Thanks, Eric
T-Red 2000 SE 24V MTX75
#587461 03/28/03 01:06 AM
Yes it should fit fine. Easy install to. You can get a $5 tool at most auto stores called a ford tool which looks like two U shaped things. Stick those in the four holes of the radio and it will pull out. You can get the harness at any car audio store for about $15. Just match up the colors to the ones on the new radio and plug her in.
Cheers
"Contours are the touchstone of the architect"-Le Corbusier 95 Contour SE (RIP..Broken Tranny until I have $$) KKM Intake Kenwood CD player Four Infinity 5x7's MTX Thunder 6500D 3 10in MTX Thunder6000's Schoche cap DEI alarm Neons
#587462 03/28/03 01:51 AM
Can I just stick 4 long skinny nails in those holes instead of spending $5 on a bent peice of metal?
#587463 03/28/03 02:48 AM
You can, but you run the risk of jacking up either the OEM radio or the dash or both. If you're really careful, it should be ok.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
#587464 03/28/03 03:23 AM
bent clothes hanger should work fine to remove it.
Moderated by  dnewma04_dup1
