Posts: 14 |
Does anyone know the size of the nut that holds the brake rotor onto the wheel hub? I have the Ford Maintenance CD and it doesn't specify. My biggest socket size in my set does not even come close and I have a pretty large tool set. I stopped by Sears to buy a larger set of Craftsman sockets but once you get to large size sockets they sell them singly at around $10 each. Not wanting to dish out a huge amount of cash guessing, I was hoping someone may know offhand.
Thanks in advance,
Bob
1999 T-Red SVT Contour
1993 Silver MKIV Toyota Supra TT BPU+
Posts: 873 |
Ummm, the brake rotor isn't held onto the hub by the hub nut. The caliper is what holds the rotor in place. Once you take the caliper off you can remove the brake rotor.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 1,228 |
Originally posted by Qbert: Ummm, the brake rotor isn't held onto the hub by the hub nut. The caliper is what holds the rotor in place. Once you take the caliper off you can remove the brake rotor.
What he said + your rotor may be rusted on to the hub.
You may need a puller to get it off. A hammer will take it off too, but may damage wheel bearings. I would stay away from hammers
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
Don't forget you may have some Tinnerman nuts on there too (they look like little star washers on the stud over the rotor)
My advice, use plenty of PB blaster, try to get it to work in inbetween the rotor and the hub, and lightly tap the edge of the rotor with a rubber mallet (or equivalent) until the rust comes loose from the hub. If you get desperate, use heat, but be careful not to concentrate the heat too much near the bearing, just in case.
Posts: 14 |
Oh damn, thanks for the info.
I just misunderstood the Ford Service Manual picture. It looks as if the hub nut needed to be taken off. Hell that makes it way easy now. Thanks guys
Bob
Learned patience the hard way
Posts: 2,454 |
In case anyone wants to know, the hub nut for the CV shaft is 32mm.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 1,508 |
Originally posted by Buckshot77: In case anyone wants to know, the hub nut for the CV shaft is 32mm.
Rick
Yeah, that thing looks pretty damn funny on a 1/2 inch drive!!!!!!
1998.5 E1 SVT Contour #5482/6535
