Posts: 9,602 |
Originally posted by Qwk98svt: Would a Venom Nitrous kit be described as "Highly Modified" would my TB work better on nitrous?<- A possible mod for me. Thanks
No.
Nitrous is adding it's own unmetered air (so to speak). It is not drawing in more air.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,292 |
alright i'm in the same boat as this guy, mine was sent yesterday.so basicallywith svt uim, svt lim, svt maf, this would be a bad modification? great?!!
"Youth ages, immaturity is outgrown, ignorance can be educated, and drunkenness sobered, but STUPID lasts forever."-Aristophanes.
--93 pgt,headers,intake,borla=14.9 1/4mile
Posts: 9,602 |
Originally posted by tour96se: alright i'm in the same boat as this guy, mine was sent yesterday.so basicallywith svt uim, svt lim, svt maf, this would be a bad modification? great?!!
VERY much so for a non-SVT.
A little searching could have saved you all of this too.
BTW - the SVT MAF is the same size as a regular MAF.
2000 SVT #674
Posts: 705 |
hey tour96, I put on a 4.6 TPS and now it runs smooth, It was from a 96 GT I aid $30.00 at advanced auto, but when you get your TB be prepaired for doing some modifactions, also durig install make sure to disconnect your battery to reset the comp. Later
-Jeff-
1998 Black SVT
Morette Twin headlight conversion
Street flight turbo kit collecting dust!
Rebuilding my 3.0L
check it out
Posts: 705 |
Would there be any gain to putting a 3.0 uim on my car? thanks
1998 Black SVT
Rebuilding my 3.0L
check it out
Posts: 4,292 |
hey qwk98svt, was it worth the 95$ maybe you could pm and give me some instructions, sometimes i lose what little patience i have and half ass things
Posts: 6 |
Just to clear my name here guys. This is the first problem I have heard of since I started doing these. I have done at least 50 and have sold all of them on this site. No one has been disappointed. I had read before that the tps from the Mustang would give the wrong signal, which would cause idle problems, so I started not sending them recently. From now on, I will send the tps along with it. I have also read that these are a great mod for FI and 3L contours. I had one on my SVT, with ported manifolds and heads and showed a 10th better quarter and about 3-4 hp on a G-tech. I know the g-tech isn't the most accurate, but if you get a good baseline with the same meter on the same road and same conditions, it can tell a lot. Anyway, I want people to be satisfied here so I am willing to work with you guys. Thanks.
Posts: 624 |
Originally posted by DemonSVT: VERY much so for a non-SVT.
I got a refund for my 65mm TB. $65 was too good to be true. So instead I emailed Buckshot77. He will do me right with an optimized Contour SVT TB for $175.
Sold 1998 Contour LX 13.868 sec 1/4 mile time.
Two years of rental cars, seriously.
Holding out for 07 Cobra Mustang.
Posts: 4,713 |
Rick did a really nice job w/ my 60mm TB. I mentioned to him that I took some super fine sandpaper to the inside of the TB (where he ported it open). It came out very very smooooth.  I'd recommend the superfine paper if he hasn't done it for you.
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 1,516 |
Originally posted by purePro5: Just to clear my name here guys. This is the first problem I have heard of since I started doing these. I have done at least 50 and have sold all of them on this site. No one has been disappointed. I had read before that the tps from the Mustang would give the wrong signal, which would cause idle problems, so I started not sending them recently. From now on, I will send the tps along with it. I have also read that these are a great mod for FI and 3L contours. I had one on my SVT, with ported manifolds and heads and showed a 10th better quarter and about 3-4 hp on a G-tech. I know the g-tech isn't the most accurate, but if you get a good baseline with the same meter on the same road and same conditions, it can tell a lot. Anyway, I want people to be satisfied here so I am willing to work with you guys. Thanks.
Mine, according to the APEXi, with the Mustang TPS idles at roughly 850 RPM normally, the "stock" idle is 720 RPM, so it's a little off. I have had on occasion to idle at 720 after it sits for 5 minuets or so, but it won't ever go down to that RPM sitting briefly at a stop light. The APEXi also shows that my TPS reads 0% so it COULD be just the idler hole that might need to be covered and re-drilled. I have a report of my test (SE's 53mm TB to the 65mm) at the track HERE So judge for yourself. I'm hoping to go to the track with my new exhaust system next week and kick some butt!
Mazda 6S, V6, Speed Yellow
5 Speed, Sport package
Bose audio
Painted 'stash and HIDs!
w/Injen 1/4 14.750 @ 94.94
Former car:
99 Contour SE Sport Black MTX V6
SVT plastic...
1/4 - 15.012 @ 90.58
