When I use the remote trunk release on the car, it will unlock the trunk, but then a loud buzzing sound comes from the trunk latch area for about a 1/2 second. It does this consistently.
All other aspects of the trunk work fine. That is, both the trunk release lever near passenger seat, and the trunk key unlock the trunk without any buzzing sounds.
Anyone have a clue?
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
