best place to order is tirerack.com
they seem to have it all covered when
it comes to heat cycling
shaving etc...
Qbert, maybe my theory is wrong,
but I've read that you lower the pressure
on the end of the car thats sliding out
so if you have problems with understeer
lowering a little can help.
Think of this, more air in tire the harder it is.
thats why its able to slide out in the rear.
Now with our cars with the 4 link in the rear
and "passive" rear steering you want some play
in the suspension, so it can travel and make
all those cool geometric changes
Really i've set my car up both ways firm front, loose
rear, and vice-versa... and alot of combinations in between..
I can tell you this.. alot has to do with the type of course
I'm on.
When in Peru I ran opposite setup as the SVT tour, and
we were within .2 of each other, now driver skill has to
have some factor. And when I ran the T&T I ran times so
close to each other with both set ups... I can't say for
sure which works better, heck I'm not sure which I like
better..
Well..back to the garage gotta fix this beast... :P
