tbunder Offline OP
sometimes. today, i slammed hard on the brakes, they locked up and then the abs light came on. i shut off the car and restarted it, and it went off after resetting itself again (i saw it go dim as it always bogs down the headlight at night when it resets). could there be something wrong with abs or what? the car locked up, but in the snow i can feel the abs working. so i know it works. any ideas? thanks a lot.
i will always have a comeback! :o)
N
N
Thunder...
I recently had the exact same problem. Under light braking (dry or icy roads) my ABS worked fine. However, under hard braking (slapping the peddle down)...my light would come on and stay on until I restarted the car. All would work fine until I had to slam the brakes on again. I took it to the dealer and it was my ABS traction/anti-skid module. They replaced it and all is fine. Thank goodness for warranty....the unit was $850.00.
Good luck
Norman
Montreal Canada
1998 LX V6 ATX
Leather
Moon Roof
CD
PW PL AC Cruise RKE
check the fluid level in the master cylinder laugh
E
E
When the ABS is used under hard brakeing, or slick conditions. It sets a code from your ECM. Its is nothing to be concearn smile ed about. On Ford`s you need to disconnect the negitave treminal for atleast 2 minutes. This will clear the codes.
If the problem percist then you mey have a historical code, which may mean that the ABS sencer is not operating proplery..
Get someone to scan your Tour if you still have a problem.
98 LX,
Eibach`s ....
ICWrims / Potenza`s....
Svt kit w /duals...
BASF Extreme Ocean paint( complete color change)....
Bullit gas door....
Fuba DSM rear mount roof antenna....
Pre 98 trunk....
Blacked out headlamps, W/ Eyebrows....
A6 Side markers....
Shaved antenna and deck lid lock...
4 wheel disc brake conversion....
Magnaflow resinator....
SVT gauge cluster....(Yes the SVT gauge has a O/D light)....
Complete mesh grill treatment, Not gutter guard....
Titinaum window tint....
Burgman custom Power window & lock conversion....
More to come as soon as i complete this one.
Yeah its a LX but it has a 2.5 and it looks better then your ricer smile
