I posted once before and little feedback. I have noticed that my car upon hard acceleration pulls the front end sideways motion to left and up and letting off completely plows to the right and down.
also when I'm turning to the right ONLY the car at one points grabs and hooks hard to the left. When I find this sweet point I can't make it the car go go left to right by just pressing the gas. Terry said it mike be differential but there no clunking.
I also have the phantom Grip in there when installed year ago did not interfere with it.
I was so mad I brought it to get another alignment and they said it perfect except for the right rear tire was about 1 degree out which cannot be adjusted. Could this be it?
Or is it the phantom grip which is just two plates with a spring betweent the spiders gears maybe grabbing.
Help I'm pissed at my car. I need this fixed before my turbo comes in.
99 SVT #198
Blk/blue
Grizzly clutch
Phantom Grips
K&N open
Resonator removed
BAT 22mm
15.4 @89mph
X
X
It could be your differential...before getting a turbo kit i'd invest in a Quaife LSD...it'll give you solid accel. off the line, and you're gonna need it with the turbo...i had to get one on my old neon when i got my turbo...and if you dont have it already, get a clutch kit and a lightweight flywheel...
nick
98.5 Silver Frost SVT
Bone stock for now, but waiting for turbo and NOS
motor mounts do the same things your describing..if i understand them right..tranny mounts too
96 zetec gl.dynomax exhaust(self bent) KKM intake..Bridgestone Potenza RE-910's...other mods also
87' Ford Thunderbird..Now my daily driver ( the wife uses the contour mostly) true dual exhaust with the super mystery mod.(hey there not even there!) tinted windows and stereo upgrade. the $200 car is starting to be a great car
Torque steer?
The phantom grip is a POS.
Possibly control arm bushings.
Broken sway bar link.
Engine/Trans mounts.
2000 SVT #674 - Check it out!
thanks yall for the help
I think Demon is making sense because the front ends feels reals loose like it moves when under a bind. I was told by the guy that the front was sound and was not loose. I saw him pull on the wheels and tug.
Is it possible the bushing could not be felt and by looking at them should I be able to tell. I have'nt had a chance to get under my car. thanks to gravel driveway mad
I know it not tourque steer because the car never done this before.
And I have to say I put the ES mounts in front. Lately I noticed the car in reverse will sometimes clunk softely.
How would the transmission mount create the pull effect?
How much does it cost to fix these control arm bushings.
Could the rear bushing contribute because there worn on the camber?
confused
99 SVT #198
Blk/blue
Grizzly clutch
Phantom Grips
K&N open
Resonator removed
BAT 22mm
15.4 @89mph
hmmmmm...interesting...when my tranny was replaced i had a couple bad tranny mounts replaced by dealer....i looked and the engine mount by the coolant res looks new and the one down by the radiator, but the one directly over the tranny looks old....anyway since then i just had the serp belt changed and now my car pulls hard to the right....i added air to my front tires yesterday (but need to double check them today) and i even retightened the lugs on the right front wheel and those things seemed to help but my car is pulling kinda hard to the right now and its never done it before....im just wondering what they coulda done while changing belts that would mess up the steering....
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
How would the transmission mount create the pull effect?because its directly bolted to the engine and the front wheels. if its allowed to move it will cause you problems with torque steer
BurritaSVT,
Have you had the Lower Control Arm Bushings checked ???
When the car is on the Alignment Ramp, they may be in perfect alignment.
When the car is being driven, the driving force, could be putting just enough pressure
on worn busings, to make the lower arms move out of alignment.
Terry Haines is working on rebuilt lower arms with new bushings that are either Urethane, or have GREASE fittings.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Did this happen after installing the ES mount bushings? I have similar problems after installing the ES bushings. I removed them and it still happens. I was told I shifted the drivetrain during installation.
Paul Dippel
93 SHO MTX
99 SVT Contour
68 Mustang Convertible
http://www.fortunecity.com/silverstone/alfa/971/
