Page 1 of 3 1 2 3
Andrei Offline OP
k - guys here's the thing
I habe 98.5 se and today, (second time in about a month) i saw the airbag light blinking like this: 4 flashes, short pause, 5 flashes, long pause. i called some ford dealer and he told me that on my car there's no recall about airbag sensor. BS?
Thanx guys!
Andrei.
98.5 Contour Sport SE,V6,MTX
beeeph.
I have a simular problem with mine, here goes..... three blinks than two then long pause. I have no horn or cruse control. Who knows.. I think youmade the right choice going to a dealer for problems involving airbags. places like Tirekingdom are good for some stuff but sometimes you have to go to the dealer for the more sensitive items.
1998 Contour 2.5 Non-SVT (ATX)
SHO Y-Pipe
K&N Drop-in
I saw my airbag light blinking the other day too it didn't happen again,dunno it's working or not, time is tough just fasten my seatbelt tight.
Thanx guys!
An Air bag 4-5 code says:
'LH crash sensor not mounted to vehicle properly'
The recall specifically addresses this problem. The dealer should replace both left and right crash sensors.
Search the forum archives for the recall number.
A 3-2 code is:
'Driver air bag module circuit high resistance or
open.'
This one sounds like the clock-spring - consistent with no horn or cruise.
This was discussed recently. Search the forum archives.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
A 3-2 code is:
open.'
AL
and i've had BOTH! You beat me to it!! laugh
AL
.....what is a clock-spring?
SHO Y-Pipe
K&N Drop-in
Administrator
Administrator
Originally posted by More-Power:
[b].
AL
.....what is a clock-spring?[/b]
Clock spring is a thin ribbon of wires that is inside your steering column. Those wires connect the airbag firing, and cruise control buttons. Oh, and also the horn.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
well then that is my problem because all three of those don't work now. Time to get out the wrenches....
SHO Y-Pipe
K&N Drop-in
If you are going to take out your airbag, DISCONNECT THE NEGATIVE BATTERY CABLE FOR 20 MINUTES!!!!! Unless you want an airbag in your face. Just wanted to make sure you knew. smile
Thanks for the info. I can thinks of better things to have in my face then an airbag....
SHO Y-Pipe
K&N Drop-in
Page 1 of 3 1 2 3
