While you're idling, there's not as much airflow across the radiator to remove the heat from your coolant. This effect is especially noticeable if you idle for a bit after driving on the highway, say, when you pull into the drive-thru at Burger King.
In other words, it's normal. Eventually, the temperature gets high enough to kick in the high-speed fan, at which point the temperature starts to drop.
The water pump has failed if the temperature gauge pegs "hot" and you aren't able to get hot air from the ventilation system.
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing?
