Posts: 29 |
i did the th fix today and drove afterwards but did not notice a difference. does it take a few days or drives for the computer to reset itself? did anyone notice a difference right away? it still hangs pretty good in the higher rpm range. i didn't hear any moosing but for me it isn't that frequent so im not sure about that part yet. i have a conical filter in so i tried both recommended size holes and didn't notice anything. any ideas??
thanks.
98 SE 24V DOHC MTX
-17" konig tantrums wrapped in 215/45ZR17 Falken Azenis ST115, sho shop cold air intake, arospeed sport muffler, taurus 24V badges, custom painted grille, stock foglights added,
Posts: 2,857 |
you did unhook the negative battery cable,or the #4 and #11 fuses after you did it right...also drive the car through a normal drive cycle after resetting the computer...
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
Posts: 387 |
i didnt notice anythin afterwards either and i reset my comp too.
Posts: 9,602 |
What size hole did you put in the plug? There really is no one-size-fits-all hole size. Just good points to start with.
Are you sure the plug is seated flush?
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 387 |
Posts: 9,602 |
Originally posted by SVTpyr8: i think 11/32 i think
Try smaller!
That's much larger than the recommended starting point IIRC.
Mine's under 1/4"
2000 SVT #674
Posts: 1,247 |
Originally posted by chrisilversvt: you did unhook the negative battery cable,or the #4 and #11 fuses after you did it right...also drive the car through a normal drive cycle after resetting the computer...
If you pull fuses 4 and 11, there's no point of disconecting the battery becuase those fuses shut the power off to the computer anyways. I pulled my fuses without pulling the battery cables and after that I put the drilled pipe cap in and then put the hose with the cap on and then I put the fuses back in, turn on your headlights and a/c and fire her up. That's my way of doing it so I won't have to reset my radio all over again.
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 3,506 |
Originally posted by 2KSESport: Originally posted by chrisilversvt: you did unhook the negative battery cable,or the #4 and #11 fuses after you did it right...also drive the car through a normal drive cycle after resetting the computer...
I honestly am not trying to be an A$$, but if you look close at the first quote, it says Quote:
He put "or" in his post. Just giving you the heads up. Im just sayiong so now one gets pissed at each other because i ahve seen it happen over little things like this.
Roz
Posts: 9,602 |
2000 SVT #674
Posts: 585 |
Now you've done it.. my brain officialy hurts..
Although I'm surprised at the correctness of your statements.
..on topic: careful with the hole size. I ran mine on the "too small" side of things, and my car would throw codes for the IAC valve, and actually destroy IAC valves every couple of months.
