If any of you have this condition, you are gonna be in for a hell of a suprise when you see a problem. The condition is with the shifter while in neutral. If you grab your shifter and it moves excessively right and left while in neutral, and i mean more than a wobble. There will be a problem with your tranny very soon. I lost all ability to shift into any gears, when this happened i was scared!!! The problem is a small carbide pin in the upper tranny that connects the linkage into the shifter. If this happens to go on you the shifter will row perfectly around the gear pattern with no gear stops, except the reverse lockout. The repair cost me $500 dollars!!! Mostly labor, because the part only came to about $10!!! My advice is to get it fixed before it breaks...
98.5 Silver Frost SVT
Bone stock for now, but waiting for turbo and NOS
