According to the Ford TSP, TPS voltage is as follows:
KOEO (key on engine off): .53 - 1.27 Hot Idle: .53 - 1.27 30 MPH: 1.0 - 1.3 55 MPH: 1.1 - 1.4
There is a also graph that shows TPS varying between .65 volts (at idle) and 4.538 volts (at WOT).
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
