9
9
sThe flexible exhaust pipe after the header has small whole.
Any suggestions on a fix for this there is a small hole and it may not pass state inspection dealer wants $300 just for the part. Also bolts are rusted bad. Are the bolts welded onto the header or are they replaceable?
Any help is much appreciated.
On another topic any suggestions on struts I see there are many options out there I would like something as an upgrade not
really iterested in adjustable or racing just something of an improvement over stock and is a basic bolt on. Also how do local garages feel about doing this kind of work.
Thanks
JTC
95 Contour 110K / Tranny slipping / Steering Play / Non-functioning door locks/
Replaced Both front Wheel Bearings exactly 1year apart/ Replaced coil at 105k/spedo cable and sensor twice
/Did TSB repair on Parking brake works fine now/Alpine CD Deck.
Talk to the folks on NE-CEG forum, some of the guys have modded their cars a lot, they can tell you what you need to know.
also...you got a pm
Regards...
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Check your messages. I have a stock 95 flex pipe for you.
Scott
If he is not interested I will takeit off your hands!!!
Pete P
9
9
tw0wheelin
Thanks for everything. The FedEx package was waiting on the doorstep as the email said it would the flex pipe looks good. This should get me through the inspections till I can trick out the exhaust as you did.
Thanks
jtc
laugh laugh
95 Contour in NE
i can get you a deal on struts......you can find me in the NE forums wink
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
