#575556 03/16/03 11:09 PM
Could this cause my battery light to come on? If it was bad where can you get the assembly oreiley had what they called the tensioner but its only the pulley.
1995 Suburban two tone black and silver paint full black and white leopard interior 20" spoke wheels bagged fbss runnin nitrogen 2 kicker comp vr 12 1996 Contour Vtech ATX 1998.5 Silver Frost SEVT RIP(5-18-03)
#575557 03/16/03 11:15 PM
I can think of one other possible thing. Is the voltage regulator part of a the alternator or separate? I have heard before that many places will replace the alternator but not the voltage regulator if the voltage regulator is still working. Its either that or you do have a belt that is slipping for some reason. The tensioner is also a possible culprit. Try turning off all your electrical loads like cruise control, A/C, headlights, radio, interior lights, etc. If this helps your alternator could also have one or two diodes that are bad which is till enabling it to charge a little. This is not likely though as the alternator has been replaced. Check to see if your voltage regulator was replaced. Hope this helps.
#575558 03/17/03 06:00 AM
On the Contour the votlage reguator is incorperated into the altenator.
Another common casue of low altenator output is worn brushes, or as Jon mentioned one or more failed diodes the rectifier. Some places still sell altenator repair kits, (they include, brushes, brush holders, diode pack, regluator and some even come with shaft bearings) but most places don't becasue they'd rather sell you the entire unit.
I feel sorry for the people who don't drink. When they wake up in the morning, thats the best they're going to feel all day - former President Lyndon B. Johnson
