Before today, I have always had mechanics change the oil on my car. Today was the first time that I have ever changed the oil on the Contour.
When I removed the oil pan drain plug, I noticed that the drain plug had rubber around the bottom edge of the bolt head. Sort of like an o-ring/gasket built onto the bolt.
Is the OEM drain plug supposed to have rubber on the end of the bolt head? Or is this a drain plug that was replaced by some mechanic?
I also noticed a plastic washer between the drain plug and oil pan.
Is this normal? Should there be a washer there?
It seems odd to have both a rubber piece on the drain plug AND a plastic washer.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
