Posts: 18 |
i know i have seen some of you do this i just wanted to know what kind of paint you all used that will stick to that plastic during rain and heat. i also know some of you used colored stickers but finding an EXACT match to T-red is next to impossible. Thanks!
1999 Ford Contour SE Sport
Duratech V6
Many mods...
Posts: 18 |
Duratech V6
Many mods...
Posts: 5,975 |
2 options:
1. Take it to a body shop and have it professionally done (be sure to ask about their warranty)
2. DIY - go to Auto Zone/Pep Boys/etc. and use their paint book to find your paint. Duplicolor is most common IIRC. I would think you would have to sand down the rear reflector really well, mask off, primer, paint, paint, paint.
HTH
Posts: 8,301 |
I lightly scuffed the surface, and used primer, sanded, then color, then clear. Not hard at all. Its lasted almost a year now with no problems.
BTW, I used paint from paintscratch.com. Great stuff.
-Ken V.
psycho_bass@hotmail.com
Posts: 212 |
i covered mine with black graffic vinyl. it looks great. you will notice the color difference if you get close. probably as noticable as a diy paintjob. but in your case iwould get it painted professionally painted. imho t-red would be hard to match.
Rob Collins
98.5 svt blk/blue #5778of6535
I've got some mods.
Posts: 18 |
Originally posted by CRZYDRVR: I lightly scuffed the surface, and used primer, sanded, then color, then clear. Not hard at all. Its lasted almost a year now with no problems. BTW, I used paint from paintscratch.com. Great stuff.
What do you mean "scuffed"? And did you use the spray paint or a spray gun? Yours looks very nice i want to do the rear reflector and the front grille. i may do my side skirts as well if the other two come out nice. And did you polish yours or just apply the clearcoat?
Duratech V6
Many mods...
Posts: 2,369 |
I had the body shop paint mine last summer the same time they did my spoiler.
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 8,301 |
Originally posted by altimit: Originally posted by CRZYDRVR: I lightly scuffed the surface, and used primer, sanded, then color, then clear. Not hard at all. Its lasted almost a year now with no problems. BTW, I used paint from paintscratch.com. Great stuff.
I mean get the surface a little rough, use some fine sandpaper for this. It helps the paint stick better. If you dont sand the reflector a little, the paint wont last and it will peel off easy. I used a spray can. I had access to a gun, but I was too impatient to go that route. I didnt polish it, I just sprayed a couple coats of clear, and put it back on the car. The reflector and grille will be ok doing it with a spray can, but IMO, I would use a gun for larger pieces like the side skirts.
-Ken V.
Posts: 160 |
i was thinking of doing mine. I don't have the big reflector i have a 95, so it's the one with the reverse light in the middle. just wondering if anyone has done one like that and how it turned out. if you have pics, can you post?
95 Gl Zetec Atx
Posts: 1,573 |
now officially a troll, i guess. used to have a black 96 SE, until it broke down one too many times.
now I'm hunting for a motorycle.
