every time i start it up it shuts right off, only after warming it sufficiently does it stay on, ive checked all the hoses and vacuum and i just had a new ignition coil installed, any one with this problem and how to i fix it.
98.5 SVT 2.5l v6
98.5 Silver CSVT 93 Black TBird SC
This could be a lot of things - but if it's truly temperature related the ECT may be bad. This can make the PCM think the engine is already hot, so it won't provide extra fuel for warmup.
X
X
Your problem may be the IAC (Idle Air Control valve IIRC). One day I went to start my car and it would crank, fire, and then die. It seemed like the idle wasn't catching; I read through the trouble shooting forums and found that the IAC can get stuck and cause this. I took the IAC off and cleaned it and it fixed the problem.
Matt 2000 SVT Toreador #1210 of 2150
i think this could be it since its not happening now that it has warmed up, by the way what is an ect??
Originally posted by asystole:
...by the way what is an ect??
ECT = engine coolant temperature [sensor]
