Posts: 82 |
will they fit or no....
i have a 2000 ford contour and im replacing the speakers....i really want to install some 6x9 i dont want to have to "trim" the door to make them fit (i guess if i have to i will but would rather not) also will the fit behind the factory grills and will spacers need to be used
also who has done this....have u liked the results
-Y2K SVT- BORN 1/03/2000
DIED 02/29/2004
Posts: 596 |
You would have to cut out a little and they will fit behind the grilles, my friend has it done on his SVT. On mine I cut out a wood baffle to fit the 6x8 hole then I just cut out the wood to fit a 6 1/2 speaker and mounted the tweeter just below the mid sounds way better then my friends 6x9's and I didn't have to destroy my door. Just my .02 cents good luck.
1999 Silver Frost Contour SVT
2690 of 2760 Born 08/13/1999
Sony Mobile ES CDX-C90 Deck
6 1/2 Infinity Kappa Perfect mid & tweet set, 2 12 Infinity Kappa Perfects JBL P.600.1 for Bass, P.180.2 for front stage.
Posts: 1,423 |
It depends on which 6x9. Some drop right in (maybe drill new holes) and others need some help. Either trim the metal or make an adapter.
If you plan to amplify them, I highly recommend custom components over 6x9 coaxial.
Posts: 15 |
You'll be happy to know that Alpine SPS6939S are a direct fit (apart from drilling four new holes for each speaker) on the Mondeo, and prob. should also be for the 'tour. I just fitted four of these front and rear. They Rock the boat....! alpine SPS6939S Here's a pic from an front door installation on a Mondeo : Mondeo 6x9 install
Car:'97 1.8 mk2 Saloon Diamond White
Mods: Magnecor KV85 | Clear Side Repeaters | Debadged | Steeda short shifter (1st in a Mondy) | Cougar knob | dropped 40mm on AP springs and System2 struts | 4x Alpine SPS6939 6x9 speakers |
Posts: 186 |
If you get one that won't fit directly, you can use MDF spacers to mount it. Be careful though. I sorta wrecked a set of CDT HD mids doing this. I didn't notice that they contacted the inside of the door panel. It just required some work with the dremmel tool to take care of the problem.
Some 6x9's have a tweeter that does protrude a bit above the speaker cone. Something to watch for when shopping.
L.
Previous owner of a 99 Mystique V6 MTX Black
Current owner of a 2004 Maxima SE MTX Silver
Forsale:
Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
