#55428 03/08/02 02:44 PM
Mysty Offline OP
Are there any tricks to changing a thermostat in a 97 Mystique GS Zetec? I am going to change mine this weekend and wondered if there is anything out of the ordinary I should look out for. Thanks!
#55429 03/08/02 05:08 PM
Its actually pretty easy. Make sure you expect a good bit of fluid to come out...
Three bolts and a gasket right on the sie of the block. Very easy.
Kharma is very real and she is one mean b!tch.
#55430 03/08/02 06:59 PM
E
E
i drained the coolant and i had no gasket come out so none went in and i havent had a drop leak.
_Eric_
95' Performance White Contour Gl Zetec ATX
-A beautiful girlfriend next to me...what other mod is important?
#55431 03/08/02 10:05 PM
The gasket sits in a groove on the block. It may or may not move at all when changing thermostats but its there...
