JWP, I thing the 95 LX only came with the V6, so you might also want to check for loose or cracked hoses connected to the air intake. There is a recall on the engine wiring harness. If you see cracked wires under the hood, take it in! The plug, wires and fuel filter should also be checked and replaced if needed. If it runs smooth except for idle, the IAC valve could be clogged or dead.
