#569846 03/11/03 11:18 PM
sae Offline OP
I am going to make myself a home stereo sub. I have already bought the crossover components. I calculated it for an 8 ohm load.
I need to find a good sub, either 10" or 12". I was thinking of using a Car sub, has anyone had any experience with this? If I do that I would have to get a 4 ohm resistance so my crossover will still work at the frequency I designed it for.
So, back to the question:
Which sub should I get, please keep in mind there is a reason I am making one as opposed to buying one (cheap )
"Absolut Rara."
"Absolut Rara."
dnewma04 has excellent advice for tightwads looking for the best sound for no money. But he will ask your budget for a sub . . .
Balance is the Key. rarasvt@comcast.net
I'm sure dnewma04 will stroll on by this forum. Until then, I am sure he and others would like to know a few things before offering much advice.
What is the budget for the driver and/or amp if you don't have one?
What is you intended crossover frequency?
Are you using a receiver with dedicated subwoofer pre-out (like any of the Dolby Digital ones)?
What do you plan to use to power it?
What size of a cabinet is acceptable?
What mix of music to movies will it be used for, like 50%/50%? Only music?
Ever built a ported box before?
Here are a couple things to recommend without any of the above info. First, stay far away from car audio drivers in the home. Most car audio drivers that do sound good are a) expensize becuase of the brand on the cone and b) inferior to home drivers because they rely on a lot of cabin gain to get a good response. Second, if your amp can handle it, get lower impedance like 4-ohm or 2-ohm. You'll get more power out of your amp. That leads to three - the more power the better with bass. Lower frequencies require a lot more power to produce the same sound level (loudness) than higher frequencies.
There are some excellent deals on home audio drivers all the time. The Lambda Acoustics line is tops in value until the end of March.
Last for now - I'm sure Dave and others can help you get the best sound and output for your money. Dave helped me with my twin 15" subs and I later got a nice amp to give each one 500 watts. I love it!
Aaron
