#55327 03/07/02 04:56 PM
H
H
Just finished TH-fix
Not bad, not bad at all - tried many different size holes, 3/16",15/64",1/4". In my original post asking info on fix I got a reply on a 5/64" size hole - got many respones back stating this was a typo & yes it was ( way too small ) but this brought up the idea of trying 3 - 5/64" holes instead of the popular 15/64" and found that it works better. With the 15/64" hole I noticed when in 1st(ATX) and climming I could let off of the accel and it would literaly "drop" into 2nd , a little heavier than I would like. I then drilled 3 small 5/64" holes in a triangle pattern and found after doing so its ALOT harder for the tranny to change like this. Not sure why but maybe do the same amount of air passing through but at a higher rate per sq. mm confused ? anyway wanted ta let ya know for who cares & only time will tell if these smaller holes will need cleaning wink
#55328 03/07/02 06:57 PM
FYI area scales as radius squared, so three holes 5/64 are not the same as one 15/64 laugh
r=5/64=0.078125
Area = Pi r^2 = 0.019174
3x Area = 0.05752
that equivalent to a single hole of radius
0.13531
or approximately 9/64
--alex | 96 GL(sort of) V6 ATX | 98 SE V6 MTX Sport
#55329 03/07/02 07:04 PM
H
H
hehe... the wizzz , just yank the thing off! mad cool
Someone should make a variable valve that correspondes with the throttle cable eek instead of a copper cap... laugh
#55330 03/08/02 05:55 PM
Someone should make that Tornado Air airflow thing to fit in the IAC hose of our cars, that might work laugh
Ryan M. Taylor
1996 GL V6 ATX Desert Violet
{__ 15" 98SE 12-spoke wheels, 205/60-15 Pirelli HP Unidirectional Tires __ KKM TrueRev Intake __ Bosch +4's __ Pioneer DEHP4000 __ 9mm Ford Motorsport Wires __ 2.25" Dual Exhaust, Catco Cat, Flowmaster 40 Series, no res __ Mobil 1 5w30 badge mod __ Pilot Millenium Series H.I.D. 55W Fogs __ Xenon 100W Highs __ Intermittent Ford P0420 CEL Option __}
http://rmtaylor.webhop.org
AIM: Vinnland990
