Posts: 74 |
And obviously, this first time it came on, I stopped and checked the level, it is at the cold maximum. It only is on when I first start the car, and then shuts off when the engine starts to warm up, a minute or two later. Is this premature signs of waterpump failure? T.I.A.
~Bob~
*99 T-Red SVT *Custom Intake *20% Tint All Around *Mobil 1 Sythetic *Sho Shop Off Road Y-Pipe *Aiwa MP3 Player *2 Audiobahn 10'' Subs *1000 Watt Amp *.5 Farad Capacitor *Custom Mesh Grilles *Dual 3.5'' chrome tips *Lead Foot From Hades *Hyperwhite Low's, High's And Fog's
Posts: 1,367 |
this is a normal problem/annoyance in our cars. add a little more coolant to your reservoir. the sensor is very 'sensitive' in there. it likes to be a tad over maximum.
Posts: 37 |
I got the same thing happening to my CSVT. This only happens when its cold though and was wondering the same thing. I usually add a very small amount of water and coolant but don't know if this is some early signs of problems to come.
_//>SVTLAY<\\_ RED 98 SVT Contour Mods: K&N Filter, custom heatshield, 9MM Ford Racing Wires, resonator removed, BAT Handling Kit, silver interior touchup, Pioneer Stereo, CUZO headlights, clear turning signals, audi side markers, LEDs in door handles, Indigo Gauges, SVT stickers(Adds horsepower=)),painted grills, sail panel, and calipers. More to come.....
Posts: 130 |
You probably have had the car parked on an incline or slope when the light comes on at start up - right? Sensitive Sensor... Just add about an inch of coolant / water to the reservoir and it will be fine. Eurythmian
'96 Oxford White Mercury Mystique "Spree" Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife. Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL. High Beam - Cool Blues in all four Head Lights. 885s in Fogs. Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together. Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
Posts: 586 |
Check this out. FAQ
Posts: 74 |
Sounds good, I'll give that a shot, thankfully it's not the infamous water pump... YET! Thanks guys...
~Bob~
Posts: 105 |
Mine did the same thing and Ford replaced the sensor, never had a problem with it since.
Brian Pinkerton 99' Silver Frost SVT #1939/2760 Born 19 April 99 Current mods 17 Inch Enkie RS6 Wheels wrapped in Kumhos, Knauberized doors, LoTek A Pillar gauge pod, with oil pressure so far, NP-Tuning Intake, Titanium metallic tint, resonator removed, Bullit fuel door, Quaife, UR Stage 2 Clutch, Fidanza flywheel
Posts: 586 |
Mine did the same thing and Ford replaced the sensor, never had a problem with it since. Unfortunately, the dealers have no clue about these "quirks" with our cars. They changed my sensor without telling me. I took it in for recall work and I look over the slip and it said "Replace Coolant Sensor" because it stayed on. :rolleyes:
Posts: 3,165 |
I just unplugged mine. It's an optical sensor so any bit of grime in the coolant will set it off.
Posts: 1,461 |
Mine goes on and off while driving. It usually takes about 10 minutes of driving before it turns on, then it stays on for anywhere from a minute to 10 minutes, then it shuts off again (if you continue driving long enough it will come back on again, then shut off again).
The coolant was changed before this started happening...could there still be air trapped in the system which is making bubbles which is tripping the sensor??
Brian
