#567861 03/10/03 12:33 PM
W
W
Does anyone have any tips for shifting, I'm stuck at a 14.9 1/4 mile @ 89 or 90. Maybe some different shifting techniques? I'm running a 98 csvt w/ intake, exhaust, underdrive pulleys, platinum plugs, 9mm wires so I should be running better than what I am.
#567862 03/10/03 03:52 PM
that actually sounds about right to me. what's your 60' time??
#567863 03/10/03 05:08 PM
a b&m shifter might take .1 sec off that time.
#567864 03/10/03 07:36 PM
W
W
Give a run down of your entire run...60', 330', 1/8th, mph, 1000', 1/4, mph. That will help explain the low mph with your et, and help us determine if you can run any better. IMHO a 14.9 at 90 is pretty damn good(hooking well?).
2002 ZO6...462whp/410wtq pretty darn fast!11.70 @ 122 silver/black 2006 Trailblazer SS(wifes car) silver/black 2000 SVT-Turbo-sold silver/blue #1699/2150 13.83 @ 102.82 on 5psi 13.51 @ 107.56 on 8psi
#567865 03/12/03 07:57 PM
W
W
60ft- 2.35 330-6.46 1/8-9.83 1000-12.63 1/4-14.94
#567866 03/12/03 08:53 PM
Wowzers! You ran a 9.8 in the 1/8th. Then turned a 14.9 and you're only at 89 or 90? Thats a little weird.
-R-
I'm a Karate Man. Karate men..bruise on the inside. "The difference between oversteer and understeer: oversteer is when the passengers are scared, understeer is when the driver is scared." -Driver Unknown
#567867 03/13/03 07:15 AM
-R-
That's a nice way of putting it...
#567868 03/14/03 04:58 AM
Hmmm, the times look close to mine but slower through all the intervals. Let's compare (him/me):
60': 2.35/2.27
330': 6.46/6.31
1/8: 9.83/9.70
1000': 12.63/12.54
1/4: 14.94/14.97
1/4 trap: 90/93
Notice the differentials: +.08, +.15, +.13, +.09, -.03. I'd believe the 2.5 could pull on me at the top end with headers (even though I've never experienced that on a track before) if it wasn't for the low trap speed. Based on those traps, I'd be pulling away instead of being reeled in.
Something doesn't add up. Just my personal observation.
#567869 03/14/03 03:36 PM
If you really are concerned with time and not longevity you can do what is referred to as "Power-Shifting". This is when you DO NOT let up on the throttle between shifts. Keep it mashed and shift as quickly as possible and instead of releasing the clutch pedal with your leg, side-step it. this will gauranty either a faster ET or a grenaded Tranny. If you still have a warranty, give it a shot. You had better keep a couple friends close by as they will have to help push your car off of the track's property. Warranties and Insurance are voided upon entering any racing facility.
SVT Parts For Sale!PM Me. 2006 M6 Cyclone Gray GTO 1995 Mazda Protege Commuter Special 93 FXDWG Dyna Wide Glide I'm A TROLL Now!~
Moderated by  mbb41_dup1
