Posts: 21,653 |
depending on mileage on your car, you can still get recall work done for certain harnesses, including the fan control harness. recall 99MO3 , i believe info can be found amongst all the info on the main part of the site.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 20 |
yea i talk to ford and my mileage is up.. i believe they said it had to be 72k and im at 81k... so im going to try out this part that i got today and see wat happens.. wish me luck...
97 contour-Stock.. for sale $1500
90 Mustang.. 331 Ported heads,ported intake, custom cam,TKO trans 423rwhp @ 6500RPM..all motor..Sold my mustang =(...
95 Duratec.. stock for now...
Posts: 1,459 |
I believe the wiring harness recall was good for 100K.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 2,319 |
Temperature sender sends signal to PCM which decides when fan is to come on. Hi-speed if a/c on, lo-speed for normal coolant temperature increase. I believe hi-speed also comes on if excessive coolant temp is reached.
In you car hi-speed relay feeds fan motor directly but the low-speed feeds thru' a dropping resistor (the part you have puchased).
You don't state location but, if warm enough, you could turn on a/c and check hi-speed fan operation. Alternately pulling the relays and jumpering the appropriate relay socket terminals to simulate contact operation is a means of checking. Latter procedure requires substantial jumper wire and battery covered with towel as precaution.
Underhood wiring harness has a long extended warranty and the heater fan switch and dropping resistor a shorter one.
Posts: 20 |
update- the fan doesnt come on at all.. so no lo or hi-speed testing is possible.. the relays in the distribution box have been replaced.. the warranty on the heater blower switch is 72k.. i called again today.. now the part i bought says resistor on the package and is located at the bottom of the fan shroud.. i looked at it today and it looks like i have to take the entire fan/radiator out to change.. going from teh bottom of the car you cant pull the resistor out bc its on the inside fo the shroud.. now im hoping that i can unbolt part of the shroud and pull it forward so that i can pull the resistor out from the back.. any opinions on that?
Posts: 20 |
UPDATE: aright i changed the sensor at the bottom of the fan shroud and the resistor or whatever it was called is burned up pretty bad and rotted out.. so i thought thank god ive solved this... i was wrong.. i put it all back together.. and the fan STILL didnt turn on.. right now i have it hot wired to a switch to keep it cool until i can come up with something else... any other ideas? i think ive just about tried everything...
Posts: 2,319 |
Update posted 03/17 @ 2:07pm Originally posted by andre331: HEY everyone i posted about a week ago or so bout my 97 contour that the fan wouldnt turn on.. Ford had it for bout a week and was tryin to figure out what wrong with it but we found out it was the relays, good to have it back... but its probably goin up for sale cause i originally bout it for my gf and she just got a new monte carlo(yea its a chevy, shame on her) but i got two mustangs so if anyone is interested email me nosstang331@aol.com thanks everyone for replying to my earlier post.. andre.
