Originally posted by holycowSVTpaul: Plastic is on the metal slide where the window bolts at the bottom.
I believe that there is another plastic pulley at the top of the "metal slide" as well.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
