I had a similar rattle on my other car (a Bimmer) and it turned out to be an exhaust support bracket under the car. The bracket had rusted through and was not supporting the exhaust anymore. Thus, the muffler would vibrate against the bracket.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
