It is a '95 GL with the 4 cyclynder engine.
I'll get the VIN to you later.
The car has 166K on it, so would it still be covered? I think that the radiator fan problem is still available from thew recall they issued.
I've been involved in the pro audio world for 25 years, so I KNOW that bare wires are no good!
I wish I knew the voltage and amperage present on those wires. I'd have to peel the insulation back even further to get a meter on them to measure it!
I am going to put silicon glue over the tiny cracks and see what happens. That should seal the conductor wire where the insulation is cracked.
Unfortunately, there is no other way to deal with the cracked wires other than to replace the entire harness (unless it breaks down into seperate wires which I doubt it does.)
DB
