Page 2 of 3 1 2 3
F
F
Yeah, I know they are easy to change, not much more than a 20 min. job. I'm just lazy I have always had a bit of surging at high rpms, even with smaller gap, but I may have had other things not quite right at the same time, so I will try the smaller gap again.
Simon new- '04 Dodge Dakota 4x4. V8, 5spd FOR SALE Black 98 SVT EO (#2119 of 6535)- SOLD! New project-'88 Ranger 302 swap.
9
I have tr55s gapped at .045. I have my pro-flow 75mm w/k+n, shoshop y-pipe and replaced resonator.
Besides shortening the gap, anything else I could change that won't cost too much? I have a proflow optimizer, but I'm scared to put it on.
95 SE Modded - Gone 98 E0 Black SVT - Gone 98 se sport - Broken 00 T-Red SVT - Nice
Yes, hence I run .035 gap and NGK TR6's.
What is the difference between the 55s and the 6s??
Jim
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, H&R's/Konis, BAT 22mm Sway Bar, 17" Momo Arrows, Michelin Pilot Sports, Sparco Front Brace, HPP Rear Brace, PIAA fogs & headlights.
The 6's are 1 step colder.
The colder you go the more easily motor damage can happen. The way I understand it is that the plugs act like a fuse. Hotter plugs burn out easier. Plug burns out the piston does not.
SVT Parts For Sale!PM Me. 2006 M6 Cyclone Gray GTO 1995 Mazda Protege Commuter Special 93 FXDWG Dyna Wide Glide I'm A TROLL Now!~
How do you determine what gap to use?
Honestly, I went big .040 and experimented until I found the right gap. I kept running it and regapping until the spark quit blowing out.
That makes no sense...
A colder plug resists detonation better because it retains less heat.
For choosing a plug's heat range you want to run as cold a plug as possible without causing it to foul out because it's not hot enough to self clean.
A plug's heat range is basically it's ability to transfer heat to the cylinder head and it's water jackets. Therefore a colder plug transfers more heat and as a result has lower cylinder & plug temps. (I.E. ideal for high CR or Forced Induction)
Which plug do you guys recommend for using with the VCN-2000?
Does it depend on the size of shot I use?
thanks
Page 2 of 3 1 2 3
