Kubiak Offline OP
i changed my headlights to silverstars today, and noticed that my left front turn signal and left rear taillight are out
ive known the taillight to be off at times, but never noticed the front turn signal until today
the blinking action for both works, and the brake action works for the taillight.. just the standard parking 'on' lighting is not working
i figure it is a fuse, but the right front and rear work just fine
also: i tested the voltage and found it out in the back, examined the filaments, and they all seem to be intact
i suppose it could be a damaged wire as well, though i figure the lights would either work or dont work if it is that.. i cut an extra wire and spliced it back when modding the foglights to come on by themselves, perhaps that is it
anyway, my questions are:
where is the left parking light/taillight fuse?
is it separate from the right hand side fuse?
are the front and rear lights connected?
are they accessible in the inside nearish to the foglight wiring?
sorry for all the questions, im trying to make sure i get this solved
T-Red 1998.5 Contour SVT Mods: Foglight 'hack' Manual Antenna switch (Thanks for the idea Ryan Wood) 20% tint all around
H
H
Circuits are split; left is fuse 33 7.5 amp interior fuse panel, right is fuse 35. Power to the fuses is via separate R/Bl wires from headlight switch.
W
W
Bingo
