Posts: 29 |
i recently bought a new shift knob for my MTX and upon installation realized it would not fit due to the reverse lock-out. after looking into it and seeing exactly how the reverse lockout functions, i said f*@! it and just removed it to put the new knob on. of course, this means the stock shift boot no longer fits, so i shined up the shift rod and there is currently about 1.5" of the rod showing before the shift boot covers the rest. I actually like the look of it, but my question is does anyone have ideas to make it look more like a race setup, possibly a very short shift boot or something flush with the console and then just have the chrome rod look going. ANy ideas or suggestions?
98 SE 24V DOHC MTX
-17" konig tantrums wrapped in 215/45ZR17 Falken Azenis ST115, sho shop cold air intake, arospeed sport muffler, taurus 24V badges, custom painted grille, stock foglights added,
Posts: 9,196 |
If you could find someone with machine shop skills, have them make you one of those gates found in Ferrari and eliminate the boot all together. If you did this you would be the first one to do it, I think  Good luck to you!
"THEE" Roger R
USMondeo@aol.com
2005 Crossfire Limited coupe'
Puur-fection Auto Detailing
Posts: 10,015 |
Roger, it wouldn't work as our shifter mechanism is too sloppy, unlike a Ferrari that is extremely precise with no play in the shifter. I think a shortened boot would work. IIRC Krafty was selling them on the forums. Do a search under "username" Krafty and you should be able to find him and send him a PM, dude!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 186 |
Originally posted by Stazi the Aussie: IIRC Krafty was selling them on the forums.
Yes it was Krafty that was manufacturing them and selling them. He did excellent work and you'd be qutie happy with his stuff. I think he even did custom jobs, where you choose the colour of the boot and the colour of the stitching too. I believe he had colour matched leather for the SVT blue interior too.
L.
Previous owner of a 99 Mystique V6 MTX Black
Current owner of a 2004 Maxima SE MTX Silver
Forsale:
Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Posts: 9,196 |
I have Krafty's shift boot as well as his e-brake boot. He installed them last month as well as my B&M short throw and let me tell you the boots are VERY high qualtiy, as was the installation of the boots and shifter...thanks Krafty
"THEE" Roger R
USMondeo@aol.com
Posts: 331 |
Thanks for all the support and good words guys!
If you are looking for a short-length shift boot w/ or w/o custom stiching, drop me a PM and we can work out the details. If you would like to do a little research first, check out the link in my sig!
Thanks again!
Posts: 4,639 |
so did u ever get the black/silver pics from the cougar guy. this combo crossed my mind. i want to add an aluminum momo knob to a steeda shifter. i'm just trying to picture if it would look tacky.
Hugo AIM:omegazodiac
Posts: 1,834 |
Originally posted by The Striped SVT: If you could find someone with machine shop skills, have them make you one of those gates found in Ferrari and eliminate the boot all together. If you did this you would be the first one to do it, I think Good luck to you!
Like Stazi said, you can't do the gated shifter, I tried. Though the reason seemed more to me like the location of the plate that would be needed on the console, i.e. down low where the bottom of the boot and the plastic trim ring are. The slots you'd need for 1,3,and 5 on a gated pattern actually overlap due to the width of the shifter itself. I have a stainless steel plate being made right now (if the s.o.b. ever cuts it out..long story) with an oblong hole in it (instead of gated) that I plan to use with just a smalll portion of boot sticking above the hole. I have the B&M as well, so maybe this wouldn't work well with the stock shifter.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 4,639 |
after thinking about it, i'd likely get solid black. question: will the b&m shift boot fit the steeda shifter. the steeda is supposed to be shorter than stock and higher than b&m. does the b&m boot have a little "slack".
is the ebrake boot only for the stock one. would it fit aftermarket ebrake handles (does the richbrook fit)
Posts: 331 |
Originally posted by hmouta: after thinking about it, i'd likely get solid black. question: will the b&m shift boot fit the steeda shifter. the steeda is supposed to be shorter than stock and higher than b&m. does the b&m boot have a little "slack".
There is slack to the B&M shift boots, though I'm not exactly sure if it will fit the Steeda shifter or not. If you purchase one and it does not fit, you could ship it back to me free of charge and I will make a new template if needed.
The e-brake boots are exactly the same size and shape as the OEM boots, so if the Richbrook fits under the OEM it will fit under the new boot.
