Posts: 111 |
Im getting the check engine coolant light, but my engine coolant is at a good level, any ideas?
2000 SVT K&N Drop-in Pioneer Face 12" Kicker 1999 se
Posts: 765 |
Common problem, check the search feature.
1999 Contour SE Sport MTX75 T-Red/Grey Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1 Other: cup holders, cargo net, Blizzaks, Potenza RE950s
Posts: 2,263 |
mine usually came on whenever i parked on in incline, then went off after a few mins.
Jim Hahn 1996 T-Red Contour SE 2002 Black Mazda MP5 Latest mods: sho shop off road y-pipe
Posts: 130 |
I park in a parking garage where I work and the floors are at a slant. Mine always is on when I leave work but goes off after the engine worms up. Also my drive is on a slant and if I leave the car running while in the driveway, it comes on. At first I worried about it... sounds like a common issue. I put slightly more coolant in the reservoir ( just above the MAX line ) and it seemed to prevent it from doing it as often.
Hope this helps.
'96 Oxford White Mercury Mystique "Spree" Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife. Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL. High Beam - Cool Blues in all four Head Lights. 885s in Fogs. Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together. Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
Posts: 99 |
Originally posted by MIKE W.: Im getting the check engine coolant light, but my engine coolant is at a good level, any ideas? Top off the reservoir and everything should be o.k.
ITIMIDATOR730@msn.com 98 SE ATX Sport/Black/All badges off/ding guards off/K&N air and oil filter/MAF Mod/polished intake/polished MAF/polished Throttle body/Painted rear reflector and lights w/red cut-outs/PPG badges/straight piped exh./many more.
Posts: 1,355 |
The reservoir "sensor" is a little touchy, I have found that if the coolant level is ABOVE the full line by a about in inch, it is fine and never comes on.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 130 |
Simon96SE - That's what I just said to do... works for me.
Dad of twins.
