1
1
My '98 svt Contour has been a great car and has never been in an accident. I left for work this morning and on comes the orange airbag/seatbelt (passive restraint light?) So I cycled the ignition, still on. When I got home I disconnected the battery for 5min. and it is still on. Now my car does have 78000miles but is this normal? Is there a way to fix it? I couldnt find anything on this in the "common probs area."
YOU LIFT YOU LOOSE!
Usually its a code. Count how many times it flashes, like
3-3, 3-4, etc.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
Do a search for 'clock spring'.
F
F
my airbag light flashed a few times on me.. and it turned out to be a bad battery. before you spend any money, go get the battery tested at autozone, etc.
W
W
The airbag does flash in a pattern to give you a code. Try making note of it the next time you start your car so that you can write it down and either look it up or post it on here for further help. Airbags usualy don't malfunction all of a sudden so more than likely it is something simple as I-BCruzn stated, but it is possible and I have seen it before.
5
i think there were a couple guys on here who had the light flashing too. i dont remember what the code was but it turned out that the connectors for the sensors were corroded. so if its one of the codes for that, start cleanin.
the 3.0L oval port 3.0L '98 midnight blue se
I had that code for awhile. It went away, just a dirty connection, like you said. IIRC, it was 3-4. That code was for the drivers side sensor.
1
1
Yeah the airbag light is flashing a 3-2 code anyone know what this is?
YOU LIFT YOU LOOSE!
1
1
So is there a way I can fix this or is this a problem that ford should fix? With the tsb is this covered by ford?
YOU LIFT YOU LOOSE!
