Posts: 66 |
This car is going to be the death of me. When coasting toward a light in neutral, if i try to put the car into second or third with the clutch pedal fully depressed, the trans makes a horiffic grinding sound. Have had problems before, usually resolved, but never like this. The car has had new trans, a new shifter, new shift cables, ford's synthetic gearlube. Not sure what could be causing this. Only happens when easing the car into second or third from a roll with engine at idle speed. Any help would be loved, as dealer thinks i'm crazy and claims they can't replicate. This is the same dealer who when i complained of the cold shift problem parked the car in the garage overnight before taking it out for a test though. Any thoughts or ideas will be greatly appreciated. Thank you. ted.
'00 T-red SVT '89 Dodge Raider '01 Isuzu VX
Posts: 108 |
Originally posted by driven: This car is going to be the death of me. When coasting toward a light in neutral, if i try to put the car into second or third with the clutch pedal fully depressed, the trans makes a horiffic grinding sound. Have had problems before, usually resolved, but never like this. The car has had new trans, a new shifter, new shift cables, ford's synthetic gearlube. Not sure what could be causing this. Only happens when easing the car into second or third from a roll with engine at idle speed. Any help would be loved, as dealer thinks i'm crazy and claims they can't replicate. This is the same dealer who when i complained of the cold shift problem parked the car in the garage overnight before taking it out for a test though. Any thoughts or ideas will be greatly appreciated. Thank you. ted. Ask the service writer or tech to ride with you and you show them. Then let them have a turn with you in the car. T.
'97 Contour SE 2.5 MTX
Posts: 5,805 |
Does sound like syncro/selector fork probs,shifting with the engine at idle does not help it too much as most of the lube is laying in the bottom of the trans...which is why the Bulldog Box has.....
Posts: 1,225 |
Originally posted by Terry Haines: Does sound like syncro/selector fork probs,shifting with the engine at idle does not help it too much as most of the lube is laying in the bottom of the trans...which is why the Bulldog Box has..... always have to leave them hanging don't you Terry
Ryan
Latest Mod: Mirko Splitter
Posts: 5,805 |
Hey....I've 'paid my dues'....Ryan...you know it !!!
Posts: 1,225 |
Originally posted by Terry Haines: Hey....I've 'paid my dues'....Ryan...you know it !!! Yeah I know but I gotta bust your balls a little...keeps you honest
Ryan
Posts: 5,805 |
Hows this then Ryan...'When your big enough you will be too old..!!!!!!!'
Posts: 66 |
Here's the latest... I went to the dealer after they found no problems and took one of the head service guys for a ride. As usual the gears ground shifting into second. He tells me that it may be the synchros or the shifting blocks. Whan I ask what the recourse will be, I was told that due to the fact that I am taking them to court since the car is a lemon that their stand is its not a problem. I was then told if this was not acceptible, i could leave and go to some other ford dealer. Nothing like good warranty service huh? Any ideas as to where I should go from here? Thanks everyone for the inbput. Terry, you should donate one of those to Ford so I can keep my baby.
Posts: 1,445 |
well i'd add the service jerks attitude to my lemon suit and complain to ford and anyone else, eventhough it probably wont do any good
i wish we could treat ford service dorks like taliban
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
