#1389 09/16/01 10:31 PM
Miki Offline OP
How much can i ask for 95 se with 136.000 miles. Engine was replaced year ago it has about 65.000 now the trans went out. Almost everything was replaced{brakes,control arms,sway bar links {front and back}, tie rod ends,engine mounts,now new clutch,cross drilled rotors] perfect good condition fron outside for that milage.
95se
00svt
#1390 09/16/01 10:52 PM
KBB.com
edmunds.com
try these yet?
The Car
1985 Mustang GT
The Motor
Stock 5.0 W/ Edelbrock 625 4BBL
2.25" True Dual w/ Flowmasters
The old car
1998 Contour GL V6 ATX with a few mods
#1391 09/16/01 10:53 PM
for a 95 like you describe... lots of people try to sell it for $5000 plus. Last summer, I bought my 95 SE (loaded, leather, excellent shape) for $4500 with 113k on it, and it was a steal. You should be able to sell it for around that, because dealers will do a trade in value for about $3000 to $3500, and then try to sell it for like $6000. IMO, you should put an ad in the paper for $4500, max $5000. But it all depends on the condition of the car, and the options that it has.
99 SE Sport MTX SilverFrost Duratec
#1392 09/16/01 10:57 PM
It's worth what it's worth.
With a bad tranny, I'd be really suprised if you could get better than $2K.
You said new clutch, so is that bled correctly and working?
Tony Boner
#1393 09/17/01 03:19 AM
Miki Offline OP
sorry for describing the trans
It is completly done i'm buying one Monday with 26k for 400.00 bucks..It has every option possible with se.
95se
00svt
#1394 09/17/01 12:57 PM
Lee Offline
Does it have a V6 or I4 ?
Is the transmission your getting a rebuild or a wrecked pull?
Is the paint in good shape?
Does it have matching tires?
Another thing is since your wanting to sell it spend a few weeks taking apart the inside of the car and detailing it. Also you might want to buy the Zaino polish kit for the car as well. With the Paint and interior looking good you can't go wrong. Also you might want to get some engine degreaser as well. Just clean everything up really well. You shouldn't have a problem selling it.
Lee Cox
In life begins responsability...
Project Car
#1395 09/17/01 01:02 PM
That year they did not put fours in SE's
Crazy Contour Guy
1995 Contour SE (ATX)
Alpine 7863
MTX Thunder4250D Amp.
2 pairs of PolkAudio EX 572A's
MTX 2-way X-over network
3 10' BlueThunders
4 ga. Streetwires power wire kit
Esoteric zero-noise RCA's
Streetwires power block
Xenon Super Plasma White Headlight and fog light bulbs
Blue mood interior lights
KKM airfilter
9 mm Motorsport Racing Plug wires
#1396 09/17/01 03:07 PM
I got my 95 GL (lesser model) V6 5 sp 70,000 mi for $2500 a few months ago. I guess the SE is a higher model, so maybe a few hundred more? Although the mileage is higher.
1995 Contour GL
5 speed V6
1988 Mustang GT
