#54714 02/27/02 08:09 PM
I was just wondering if anyone has figured out a way of jerry rigging the trunk with some sort of spring mecanisim so that it opens better in cold weather; mine is pretty sticky. I have both cleaned, and lubed the seals on it in hopes that it would help, it did'nt. Any help is appreciated.
Craig
#54715 02/27/02 08:27 PM
Try doing a seach on trunk spring or something like that in the forums. There is a specific Ford part that mounts to your deck lid with a little spring on it to fix the problem - it gives a little extra push to help prevent the trunk from re-latching when you open it. Sorry I can't tell you the exact part number, but I know it's here somewhere since I got one for my car a year or so ago.
Good luck
Dan
'97 GL V6 MTX
#54716 02/27/02 08:49 PM
Spring Popper for All Contique Trunks
Ford Part # F8RZ-63431B04-AA
"My Name is Richard. I am a Contouraholic."
1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades;
Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod;
PIAA 9006 Super White Headlamps
AIWA CDC-MP3 HU; WeatherTech Mats
Viper 600ESP w/Remote entry
#54717 02/27/02 10:39 PM
Thanks Alot!
#54718 02/28/02 01:40 AM
The supporting struts in the trunk have bad springs that lost their pushing force, and that makes the lid not pop. I knew ford had a "smart" solution like a "spring popper" but I hate to see them make money for their poor engineering or part sourcing.
My approach to get the problem is a piece of high rebound, rubber like foam cushion I found in my son's toy bin. It's about 1" thick. I cut it into shape and cut a slot on it so that I can slide it over the lock ring on the bottom of the trunk lid. when the lid is closed the cushion gets pressed, and when lock is released it'll push the lid popped. I may need to change the cushion every winter.
#54719 02/28/02 04:22 AM
My supports have their lift, they just won't "POP" the hood. I hear it pop, but you can't see it, so I am getting the spring.
#54720 02/28/02 04:45 PM
O
O
I had that problem and it drove me crazy. I ended up lowering my trunk latch and it took car of the problem. I actually lowered the latch to stop my subwoofers from vibrating the trunk and it ended up fixing this problem. eek
laugh
#54721 02/28/02 11:48 PM
I already lowered the latch, it helped the "Pop" sound, but the lid still doesn't move.... frown
#54722 03/01/02 01:20 PM
Maybe you can try this...I moved the latch to the right (when standing in front of the trunk looking in) and it solved my problem. You might have to adjust it a couple of times to get it right.
Good luck....MarkO
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
#54723 03/01/02 04:35 PM
E
E
Spring Popper
Price $12.79 plus tax
Only need one.
'96 Oxford White Mercury Mystique "Spree"
Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX
It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife.
Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL.
High Beam - Cool Blues in all four Head Lights.
885s in Fogs.
Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together.
Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
