#54630 02/26/02 11:32 PM
E
E
My power door locks have always done this strange thing... they lock without notice by themselves. This has locked me out of the car several times with the keys inside. The Dealership is baffled. Any ideas?
'96 Merc Mystique
eek
'96 Oxford White Mercury Mystique "Spree"
Equipped with a stock 170hp Duratec 2.5L - V-6, 4 speed ATX
It's a Tubeless Tique!!! ( DFW will understand... )
Purchased NEW @ $18,756.00 on 1/11/97 with 25 miles on the Odometer for the wife.
Now has a little over 57,000 miles on it and it's my ride after getting the wife a 2000 Windstar SEL.
High Beam - Cool Blues in all four Head Lights.
885s in Fogs.
Head Light Switch Wiring Mod ? Can now run with Parks and Fogs together.
Updated the sound system and did sound proofing (What a difference!).
Dad of twins.
I'm such the family man.
did you try the batteries in the keyless entry or maby a stuck lock button try not keeping the keyless entry remote with you, leave it in the house, maby that is your problem.
dont let bambi hurt your contours!!
cause i didnt quite kill him!!
i think i hit thumper too?
98 contour se--- drilled out intake box and straight pipe exhaust-- lot more to come!!
94 dodge shadow es-- cant dodge anything with the whole 50 hp damn that thing is slow!!
Administrator
Administrator
Has the door every been apart before?
I had a body shop put a screw through the wire bundle during reassembly and it caused all kinds of weird things.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
my car does that too....if the key is in the ignition (and turned on) if i get out the car and let the door close im locked out...now if i have my windows down it never seems to do it naturally
actually i thought it was part of the design...to lock the doors automatically when the key is on or the engine running....
i got locked out twice...once trying to take my g/friend to work one morning...was wiping off the windows and let the door close...with the engine running...she was trapped in the car for hrs eek laugh ...thankfully the window was cracked and we found a piece of wire in the garage and i was able to mc guyver the wire to hit the window switch and get the door open
the second time was at the car wash but my trunk was open so i let the seats down and climbed through and opened the back door.....not as easy as climbing through my 16v gti
now i carry the spare key in my wallet
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
That's good for the guy who picks your pocket. :p
Yah but what if you leave your wallet in your car? laugh
lol, this same thing happened to my boss with his cougar, guess ford has some work to do with the locking systems. his was covered under warranty. he had the same problem 3 times in a bloody week so the dealer had to buy the car back from him. good luck...
1
1
I can't lock my keys in!
If it happens when the engine is running, it is NOT the remote keyless entry. It is disabled while the motor runs. How do I know? Left the car running on a cold morning to warm up, went inside and took the remote with me and locked the doors. The remote would not open the locks. I had to run back inside and grab the spare key to manually unlock the door to get in.
I have had the same problem with my 95 Contour GL. I've been locked out after I start the car and get out to clean off the snow. I can hear the pwr locks moan and lock me in. Really bad. It really is a safety issue - what if your infant/toddler is locked in?
I always thought it was my fault - I had an aftermarket remote start and entry system installed and figured that was acting up. Sounds like that is not the culprit. Ford should address this...
Has anyone had luck fixing this problem?
