nosiy Tweets ....Is there A Noise filter i can buy to get rid of the noise comming from my tweets .The noise is IN TUNE with my motor ..the Higher the Rev on the Car the higher pitched it gets .Woorst with my Radio On ..not to Bad when playin CD's but still does it in between songs . What can I buy for this and most of all what causes it ..All my wires are neat . Thanks for any Help
18' Motegi MR3 Gunmetal racing wheels Toyo Proxes FZ4 225/35/18 Optix underbody Neons Audio:DHD 1000 Watt(lows) American Pro 400 (Mids) 4-5' Rockford Fosgates Carion CD Deck Pushin The Tweets . Kicker X3i Crossover DHD Power Cap
YOU MIGHT WANT TO REGROUND THE HEADUNIT AND MAKE SURE ALL OTHER GROUNDS ARE SECURE ALSO MAKE SURE THE PATCH CORDS ARE NOT RUN BESIDE POWER WIRE THIS CAN CAUSE ENGINE NOISE BUT MOST LIKELY ITS GONNA BE YOUR GROUND ON YOUR HEAD UNIT SINCE YOU HAVE THEM RUN DIRECTLY OFF IT AND NOT RUN THROUGH AN AMP (RIGHT?)
AND YES SOME ONE DOES MAKE A NOISE FILTER BUT IT MAY NOT BE NECESSARY
WAS THIS STUFF PROFESSIONALLY INSTALLED?
1995 Suburban two tone black and silver paint full black and white leopard interior 20" spoke wheels bagged fbss runnin nitrogen 2 kicker comp vr 12 1996 Contour Vtech ATX 1998.5 Silver Frost SEVT RIP(5-18-03)
Have you installed any equipment recently? If so that may be the cause of the whine.
Its commonly known as a "ground loop". The ground of one component in your system isn't the same as another, hence there is a current flow between them, causing the whine.
Making sure all your components are well grounded is the first step. Then isolating them one by one to see if which one is the cause.
If you are desperate I have a set of RCA ground loop isolators that will take the noise out of your RCA cables. Email me if you want to buy them, cheap.
L.
Previous owner of a 99 Mystique V6 MTX Black Current owner of a 2004 Maxima SE MTX Silver Forsale: Yakima roof rack. Q-towers, bars, clips, locks. Good condition.
Radio Shack makes a filter for about $20. i tried it in my old altima and it killed all speaker wine. I put the filter in the positive lead going into the head unit, then the filter has its own ground that i screwed into the frame.
your best off not using any filters if possible, but if you do decide to get one make sure u get a power filter and not just an RCA filter (did not work tried 2 diffrent ones).
- Mischief Atlanta 98.5 SVT 600W RMS pushing two infinity reference 12's Dynamat in the trunk
Uhh.... Mischief....
Ya wanna step out of the time warp? The last post in that thread was nearly a year ago!
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
Moderated by  dnewma04_dup1
