Posts: 68 |
I have a major problem with water on the floor board after it rains usually a good hard rain. I was thinking of the cabin filter would that be a possibility.
1995 Suburban
two tone black and silver paint
full black and white leopard interior
20" spoke wheels
bagged fbss runnin nitrogen
2 kicker comp vr 12
1996 Contour Vtech ATX
1998.5 Silver Frost SEVT RIP(5-18-03)
Posts: 9,442 |
Where exactly on the floorboard is it wet? The cabin air filter would mean it was wet behind and under your glove box.
Posts: 68 |
ALL OVER THE PASSENGER SIDE FLOORBOARD I HAD WATER STANDING
1995 Suburban
20" spoke wheels
2 kicker comp vr 12
Posts: 1,603 |
Sounds like your HVAC drain is clogged. You will have to remove the fan to get your hand inside the box and clean it out.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 68 |
I AM NOT VERY FAMILIAR WITH THIS SO A LITTLE MORE DETAIL WOULD HELP THANKS
1995 Suburban
20" spoke wheels
2 kicker comp vr 12
Posts: 1,603 |
The HVAC box holds your heater core, your AC Evaporator, and your fan. It has a drain in it so when water runs down into it from rain, it has a place to drain. If the box collects an unusual amount of dirt, leaves, etc, it will clog. When it clogs, water has no place to drain, so when it fills, it will spill over onto the floor inside the car.
Pete...
DOB 10/31/2003
DOP 1/2/2004
Posts: 4,693 |
There are lots of places that rainwater can enter and end up on the passenger side front floor. One of the most common is a windshield that is not fully sealed along the edge. Also the door gaskets can cause this.
It may help to look for traces of the intrusion, tracks or trails of where the water came from. Get your head under the dash and look aroud with a strong flashlight. If necessary, have someone on the outside run a hose over the general area while you are inside with a flashlight looking at some of the suspect areas.
In extreme cases, remove the seat and carpet, dry everything out, then sprinkle talcum powder around the floor, set up a sprinkler to shower the car in the general area in question for about 15 minutes, then check the powder for an indication of the water trail.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 10 |
my drivers side has always leaked water but ford says there is no problem.
2000 svt black
quaife diff
indigo gages
koni 5 way adj. struts.
intraxx 2" lowering springs
18" ASA 5 star(powder coated white) with yokahama parada spec 2
injen intake
fidenza flywheel
65mm thro. body
ur underdrive pully
Posts: 68 |
THANKS EVERYONE I WILL DEFINITELY GET THIS FIXED SOON I KNOW THAT IT HAS TO BE THE HVAC DRAIN NOW BECAUSE IT ONLY HAPPENS WHEN THERE ARE EXTREME AMOUNTS OF RAIN SO IT HAS ONLY HAPPENED 3 OR 4 TIMES IN THE 4 YEARS I HAVE OWNED THE TOUR AND NOTHING OTHER THAN THE FLOORBOARD GETS WET AND WATER HAS NEVER EVER COME IN WHILE WASHING IT AND THAT IS AT LEAST TWICE A WEEK
AGAIN THANKS A LOT
1995 Suburban
20" spoke wheels
2 kicker comp vr 12
