Posts: 50 |
Anyone installed the following on a 95 (or similar) zetec?
oil presure gauge? water temp gauge?
did you use mech or elec?
install hints/photos?
I used search feature, no results.
Thanks.
2003.5 MAZDASPEED Protege #1467, Ti Grey
MODS: Schroth 3pt harness, clear corners, CF hood, grill, mirrors, dash, etc. Injen CAI, Defi D Boost/OilP/AFRatio, Greddy SP2 2.5" Cat Back
Posts: 368 |
use electric.... much better than mechanic, and i dont even think you can use mechanic on the tours..
2002 Focus ZX3, MTX-75: A good amount of mods
2003 SVT Focus ZX5, Getrag-6: FS Stressbar
Best mod ever to my tour: A Beautiful passenger seat filler, that is my girl!!
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by JontourSVT: Anyone installed the following on a 95 (or similar) zetec?
Thanks.
Why a water temp gauge? You already have one.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 124 |
I bought a set of three gauges (Ammeter, Volts and Oil pressure) last summer and never got around to putting them in. They are mechanical and will work on our cars....you just need to ensure that you have the right connections in the right place. Don't know if I'm going to install them as I'm not sure how comfortable I am with the idea of having pressurized fluid piped into the passenger compartment via the gauges.  I agree that you don't need a water temperature gauge unless you're going to pull out the instrument cluster panel and replace the gauge there. Jonnie
98 Zetec Contour SE
Sony XPlod CDX-CA900X HU
Sony XPlod XM-2150GSX amp with JBL 8" Sub
(Not much so far but workin' on it)
Posts: 1,459 |
I'd like to have a temperature gauge so I can tell the exact temperature I'm getting. N-O-R-M-A-L doesn't really tell me anything, whereas 190-195-200-205-210 would tell me a lot. Assuming that it's accurate, or course. By the way, is there any way to hook up a 95 (OBD-I) to a laptop to monitor all the good info stuff that is going to the PCM? This would be better than a gauge, as far as I'm concerned.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 50 |
More accurate.
Posts: 750 |
Originally posted by bentleywarren: By the way, is there any way to hook up a 95 (OBD-I) to a laptop to monitor all the good info stuff that is going to the PCM? This would be better than a gauge, as far as I'm concerned.
I've a '97 with the newer version OBD and I can do that without any problem, although it's quite impractical to drive around with the laptop on the pass. seat
IIRC You can buy OBD monitors for Palms and stick the Palm to the dash...
T.
Posts: 736 |
hell i do that now but my laptop is strictly for MP3's
99 ATX Contour 130k w/ a 21k tranny freshly installed
Secret Project in the works
Originally posted by unknown: Never argue with an idiot, ppl may not be able to tell the difference between you.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by bentleywarren: I'd like to have a temperature gauge so I can tell the exact temperature I'm getting. N-O-R-M-A-L doesn't really tell me anything, whereas 190-195-200-205-210 would tell me a lot. Assuming that it's accurate, or course.
The R is about 190 degrees.
Hector
257HP/259TQ
160HP/141TQ
Posts: 1,459 |
Originally posted by LoCoZeTeC2.0: Originally posted by bentleywarren: I'd like to have a temperature gauge so I can tell the exact temperature I'm getting. N-O-R-M-A-L doesn't really tell me anything, whereas 190-195-200-205-210 would tell me a lot. Assuming that it's accurate, or course.
Thanks,,,does anyone know what the L would be? My thermostat seems to open on the high side of the R, (so I assume 195-200), but the fan turns on at the high side of the L.
