I believe that one of the cables off the Alternator is a fuseable link.
If that wire is blown, it will need replacement for the alternator to charge.
Also, it is a bad thing to disconnect the battery while the engine is running.
The internal resistance of the battery is a major component of the charging system.
Disconnecting it while the engine is running will cause a voltage spike that could fry your PCM.
